Re: pedistal seat replacement
Most pedestal seats I'm familiar with are bolted to the deck with "T" nuts embedded in the underside of the plywood. If yours are bolted, the bolts should be visible.
You should post some pics of the seats you have, mainly the base.
A link to the type of seat you intend to install would be helpful too.
I'm taking it for granted your boat is a fiberglass boat. If this is the case, then removing and installing seats can be tricky and a lot of work because existing and new penetrations to the deck can lead to water penetrating your deck and rotting your decking and everything below the deck.
If your boat is an aluminum boat it will be a piece of cake.
