Yesterday, I noticed that the water that comes out the starboard side of my motor wasn't too strong. I call it the pee hole on the top starboard side, because it is just a little (1/8 inch or so) stream. I just replaced the water pump, the drive shaft seals, and the water flies out the back two holes. Is there a hose or something that I need to look at?
PS: Just checked under the cowl, and the tube goes into the top part of the crankcase, on the port side of the motor. Is this serious? I don't want to burn up my motor!
