Peehole on '72 Johnson 25 hp
MWorks
Is there a peehole on a '72 Johnson 25 hp? I recently acquired the motor and am going to test it this weekend. Thanks.
R.Johnson
Re: Peehole on '72 Johnson 25 hp
No, there is'nt. The water is exspelled out the exhaust relief hole located at the back side of the engine, down from the power head.
breiter56
I am running a 25R73A. Would it still be helpful to add the tell tale modification to these motors? The water is visible spraying from with the exhaust, but compared to the stream of water from a tell tale it may be hard to judge. Any thoughts?
