Pennzoil Premium Plus VS XLF RESOLVED !
jwall116
I don't have popcorn... only movie theater butter.
Have done plenty of reading all over the internet regarding the differences between Pennzoil Prem plus and XLF. Seems most of everyone likes the stuff and no one really knows the difference between the two. I attempted to contact Pennzoil without any real answers. So I have dug deeper and have the below virgin oil analysis for both oils. Also added in one for the quicksilver oil for comparison. The data is from Bobistheoilguy, I take ZERO credit for the data. You can google search "virgin oil analysis #####" to find the raw data.
Penz Prem Plus - Has a small amount of Moly and a little zinc/phosphate (ZDDP)
XLF - Same amount of zinc and Phosphate (ZDDP) as the quicksilver but without any moly
Quicksilver Prem Plus - Tons of moly, zinc and phosphate (ZDDP)
XLF and Quicksilver oil have about the same amounts of Zinc and Phosphate in them. The biggest difference is that carbon causing moly.
The data speaks for it's self .... looks like the XLF does have a better additive package to it. Blows my mind that XLF is $2 cheaper per gallon when it has more additives in it.
Pennz Premium Plus -- on the left and quicksilver Prem Plus on the right for comparison
Pennz Premium Plus VS Quicksilver Premium Plus
Copper - 0/0
Iron - 0/3
Chromium - 0/0
Aluminum - 0/6
Lead - 0/0
Additives(PPM):
Molybdenum -2/1050 <<<<<< It's no wonder Quicksilver causes carbon/soot !
Phosphorus - 9/32 <<<<<<<
Zinc - 15/39 <<<<<<<<
Magnesium - 0/0
Calcium - 38/120
XLF
PPM:
copper - 0
iron - 0
chrome - 0
lead - 0
aluminum - 0
silicon - 2
sodium - 1
potassium - 0
moly - 0 <<<<<<<<< No Moly
boron - 2
barium - 0
calcium - 14
magnesium - 0
phosphorous - 28 <<<<<<< Same amount as Quicksilver
antimony - 0
zinc - 38 <<<<<<<< Same amount as quicksilver
GA_Boater
What is the big bottom line/moral to the story here???....
Oil is oil, some are less oil because of increased additives and some oil smokes more, but it's doubtful molybdenum is the reason for smokey, sooty running because not all experience the skeeter fog effect.
The moral is you can justify anything if you search the InterWeb long enough. :D JMHO
jwall116
Moral of the story is these big corporations are dishonest in their marketing. With very vague labels on their products. Claiming "For seasoned motors" is all they put on the bottle as the difference. That's a bunch of garbage, what makes it so much better? Or worse?
The point of the post is to SHOW THE FACTS. This is NOT a brand war. This is to provide the consumer with FACTS in order to make the best decision on what to put in their motor between the 2 Pennzoil products.
GA_Boater
So explain the advantages/disadvantages of these additives. A bunch of numbers with no explanation is meaningless especially when there is no comparison. All I see is XLF has a bunch of zeros for some components, while Premium and Quicksilver have no entries to compare against.
The so-called facts are incomplete and have nothing to base a decision on. You can use what you want, as all will do.
BTW - I choose to use XLF, not because of the label, but because I like the price and performance in my old motor.
robert graham
I run the Pennzoil 100% Synthetic in my 1999 C90 2 stroke....I don't know all what's in it but at $45/gallon it's pretty darn pricey....doesn't smoke much or lay up carbon, so I think it may be worth the extra price, but who knows for sure?....
jwall116
I have no problem explaining the raw data, although I am no oil chemist. The only thing left to interpretation is what you want in your engine. My whole point of this isn't to push one brand over the other, but mearly let the public know since Pennzoil doesn't, what the difference is between two of their products.
The only numbers we are concerned with are the additives, the others are wear metals and this being a virgin oil analysis of a 2 stroke oil, we will not see the wear of an engine like a 4 stroke. So lets go over the additives.
[FONT=arial, helvetica, sans-serif]Molydenum - most commonly used as an anti-wear/anti-scuff additive and has an effect commonly called ?Moly plating? where over time, a thin and microscopic layer of Molybdenum tends to form between contact surfaces, thereby creating a lower coefficient of friction between the two parts. Moly has a melting temperature of 1185 degrees Celsius and is used as a black lustrous powder in oil which is insoluble by water.
​^^ -- This statement is discussing its benefits in a 4 stroke oil/grease, NOT in the combustion chamber. Take that how you will !! [/FONT]
Phosphorus - anti-wear, anti-oxidant, and corrosion inhibitor additive
Zinc- anti-wear, anti-oxidant, extreme pressure, and corrosion inhibitor additive
Calcium - Used as a detergent and dispersant additive to maintain suspension of particulate matter, along with maintaining a reserve alkalinity.
82rude
Wouldn't moly be beneficial then ?Have any analyst's been done on lets say supertech?
jwall116
Never said it wasn't. It's a great additive for anti-wear. The downside to it in our combustion chamber is build up.... brings to wonder why such manufactures offer decarbon additives etc.....
There was a magazine company (B&W I think) that analyzed a bunch of different oils, they have since been bought out of went under but the links are dead. I would LOVE to see them, if anyone has it saved somewhere.
I suspect the Wallmart stuff is about the same as Pennz Prem plus but without the semi-synthetic additives to burn a little cleaner. I have no reservation for burning the wally world stuff except that I don't support their company as a whole. I'll pay $4 more a gallon for Pennzoil over supporting the destructive China dominate corporation called wallmart. But thats a different story !
82rude
I see your down in Texas,have you used mystic semi-synth?My 60 etec seems to be happy with it.Zero smoke but then again if an etec smokes theres something wrong.The separate pinpoint oil injection system is great.
jwall116
I have seen it in the stores but have never tried it. Only oils i've ran were Pennzoil Prem plus, XLF and Royal Purple fully synthetic. The Royal purple was fine, but actually smoked more than the pennzoil. I think its too thin of an oil for my carb'ed 1995 130. I got a killer deal on it, on close out. $10 a gallon !
XLF runs $17.99 and prem plus is $19.99.... I run the XFL. Crazy to to me quicksilver prem plus is $19.99 but that moly scares me. I don't want carbon build up in this engine. 21 years old and I can still read the numbers on the top of the pistons.
HT32BSX115
OTOH, "Supertech" might just be made by Penzoil (or other "name") and relabeled...It really doesn't matter much if the oil is licensed by NMMA.
If anyone cares, there are people on the "Bob is the oil guy" site that have nothing better to do than spend all their time researching all this stuff. One guy actually wrote to a few oil producers and asked them.
Here's his claim:
I sent an email to Exxon/Mobil, Warren Products and Pennzoil asking them if they made Supertech oils. Below are their replies:
Warren:
There are three suppliers for Super Tech oils and we are one of them. If you share with me where you are located, and specific Super Tech products I call tell you who the suppliers is.
Dietz Brock
Warren Distribution
We are the manufacturer of those oils for Michigan . The Full Synthetic is Group III base oil with a robust additive package and meets the latest API specifications. The ATF+4 is a fully licensed product by Chrysler and conforms to their quality and performance specifications. You can check out our website at MAG1.com. The MAG oil is house brand name and Super Tech products have the same product specifications.
Dietz Brock
Who are the 3 producers?: Warren Distribution, ExxonMobil and Shell Oil Products which they are also Pennzoil and Quaker State
Dietz Brock
Exxon/Mobile:
Mobil is unable to discuss third party agreements with the general public.
-- Thank you for choosing ExxonMobil products.
If you need further assistance, please contact ExxonMobil at 1-800-ASK-MOBIL
Pennzoil:
Dear Consumer; Thank you for your interest in our products. We do blend some of the Super Tech Motor Oils for WalMart, to WalMart's specifications, at our blend facilities. Sincerely Product Technical Service
Having worked in the oil industry many years ago, the people "who really know" told me that oil companies have been trading products (gasoline, diesel, jet fuel, finished lubricating oil etc) for years. (which is why there's ASTM and NMMA standards and licensing)
And as indicated above, most of the big name brands (like Exxon, Chevron/Tex, etc) do not want you know
As a result, I have never been too excited about the name on the outside of the container. In all those years, it's never made any observable difference.
jwall116
The point of this isn't to compare the big name brands. I personally wanted to know what the difference was between the two pennzoil products because it's a "SECRET!!!" shhhh don't tell. It's no longer a secret and I sleep better at night. :lol:
XLF has more anti-wear additives over the pennzoil prem plus. And its cheaper.
I have NO idea why mercury (and yamaha) put so much Moly in their product. Extreme amounts of anti-wear additives are counter productive. Stick rings, carbon up pistons, clog O2 sensors. I would love to see about half that amount in pennzoil form :p There is more moly in those two oils than there is in high end 4 stroke synthetic oils. Difference is, those oils arent in the combustion chamber being burned. If I had a direct injection merc, I MIGHT run the merc stuff, but with a carbed engine 21 years old.. with relatively low internal combustion pressures, there is no reason for all of that moly in my engine.
David Young
I use the XLF only 'because' it's sold for a cheap price and it's a name brand product from my local Walmart :). I'm sure it would cost 2 or 3 times more if it was sold at my boat sales and repair shop :(.
dingbat
Lubrication Lowdown
Story and Photos By Bill Grannis
Boating enthusiasts are an opinionated group. No boat related subject, though, brings out religious fervor and flaring tempers as much as a discussion about outboard oil. Each lubrication opinion is sacred and is not easily changed. During a heated discussion, you may have heard folks say, "Show me a Yamaha refinery," or "I've never seen an Evinrude oil well" or "Oils are all the same, they just have different prices and containers." Opinions vary from recommending the cheapest TC-W3 available to only using the motor manufacturer's oil.
Multi-tasking Outboard oil does not just lubricate. In fact, almost anything from olive oil to baby oil will reduce friction. Today you do not see "blown" motors from poor lubrication quality, but from carbon stuck rings, rust, lean mixtures, and detonation. Fewer deposit formations, the reduction of engine wear, and corrosion resistance are just some of the other "jobs" required of a TC-W3 lubricant. An outboard motor, like an aircraft engine, runs at a relatively constant speed where the average piston temperature stays high. This duty cycle makes outboards more prone to carbon buildup as well as pre-ignition and detonation damage. As a result, special additives are required for cleaning deposits and reducing wear.
Direct fuel injected (DFI) engines, such as FICHT, Optimax, and HPDI, need a very high quality oil because of their unique operating characteristics. With only air passing through the engine block, DFI motors operate with elevated crankcase temperatures and recirculated hot oil. This lubricant still has to function over time, even after the evaporation of its thinner and more volatile components. In contrast, oil in a regular two-stroke only lubricates and cleans for 1/100 of a second at 6000 rpm,. Traditional motors also benefit from an internal cooling effect as the fuel mixture travels through the crankcase. The throttle venturi area runs so cold that occasionally condensation forms on a muggy day. As of publication, only OMC has a product formulated for DFI motors, FICHT Ram Oil. It is a partial-synthetic blend containing additives to prevent deposits and to protect parts from the high temperatures generated in a DFI outboard. Other oil and motor companies had no comment when asked if they were developing a DFI oil.
Certification
The National Marine Manufacturer's Association (NMMA) sets the lubrication standards and routinely checks oils for consistent quality. Certifying a new oil costs around $150,000 per formula for all the engine tests conducted by independent labs along with a $2000 registration and a $925 annual fee. Testing conducted in these independent laboratories uses several specific engines as well as reference fuels and oils for comparison. Lubricity, compatibility, corrosion resistance and detergency are some of the characteristics evaluated. The tests are pass-fail only. Some of the severe ring sticking tests (at a 100:1 ratio) allow for 15 percent scuffing (not metal scoring) of the piston, so an oil scuffing only 14 percent can advertise it exceeds the TC-W3 specifications. None of the outboard manufactures with whom we spoke allow any scuffing at all with their oils, and the oil companies contacted would not comment.
Each TC-W3 certified formula has a registration number printed on the container starting with "R-" , followed by 5 digits. Sometimes you will see one brand with several different numbers all on the same shelf. Presently, around 650 different formulas are certified TC-W3. Numerous companies use more than one certified formula for less dependency on chemical availability and price fluctuations. Some manufacturers sell their oils in several grades, each containing different compositions and priced accordingly. Others package and sell a TC-W3 oil under more than one name, usually as private brands, store brands, and for anyone wanting their name on a bottle. According to some accounts, even a few "big name" oil companies do not even make their own TC-W3 oil but put their label on a another's brand. For them it is more efficient to sell in such a small market compared to the enormous automotive, commercial, and industrial market.
Chemistry 101
A TC- W3 lubricant is made up of many parts: base oils, solvents and multiple additives. High-viscosity neutral stock and thick bright stock make up the heavy weight base oils. These are commodities, sold like peanut oil, propane or corn syrup. Some blenders may specify a particular base oil brand, giving birth to the erroneous statement that "X" oil company make "Y's" outboard oil. Varying the amounts of each stock determines the costs, lubrication benefits, smoke output, and high-temp lubricity. Bright stock is a heavy weight oil with good high temperature lubricating properties and carries the additive package to the combustion chamber. Having lower flash points for easier combustion, neutral stocks are lighter to provide instant lubrication on startup. Synthetic compounds like Polyisobutylene (PIB) reduce smoke and provide high temperature lubrication, but are very expensive. Only Yamaha and OMC state they use PIB, the rest would not comment. Solvents dilute the thick base oils to facilitate mixing with gasoline and flowing through injection systems. Additives are like medicines; thousands from which to chose and millions of combinations, each varying in price and effectiveness. Most are nitrogen-based, verses metallic- based used in air-cooled motors, and do not show up on the analysis chart. Lubrizol, Oronite and Infinium are the largest producers of two-stroke additives.
Each blender of TC-W3 oils has a different agenda in the formulation and marketing of its product. Some aim for the price-motivated consumer, making a passing grade lubricant as inexpensively as possible. Others cater to the educated boater who wants the additional protection of a quality oil and is willing to pay for it. Many sell on brand name recognition or automotive oil reputation. Motor manufacturers design the engines and do the most testing because of the sheer number of outboards they run every year. Oil corporations know the lubrication business and have the facilities for analysis, bottling, and marketing, but TC-W3 oil is only a minute part of sales. Additive companies invent, test and make the compounds used in outboard oils. Some sell complete packages for mixing with base oils as well as individual components for specific applications. The ideal situation is when all three entities combine resources.
The Analysis
We analyzed 12 popular OEM and aftermarket oils to determine any differences in chemistry. Only regular "off- the-shelf" outboard oils were chosen and obtained from dealers, WalMart, K-Mart and West Marine. No racing oils, pure synthetics, or biodegradable lubricants were included.
After researching oil laboratories, it became clear that a thorough examination would cost over $1000 per sample and still not find every element. Commercial labs specializing in engine oil analysis test for the most common elements at a reasonable price and are set up for quick turnaround. Of these, we chose CTC Analytical Services for their reputation and nationwide network of laboratories. Ted Bernhard, manager, was eager to help in our quest and, through many phone calls, gave us a crash course in chemistry and oil analysis. He also helped interpret the results and explained why many organic compounds and proprietary formulas did not show up in reports.
The emission spectrometer, used for analysis, contains a special chamber for holding a small amount of oil and burning it in an electrical arc emanating from two graphite electrodes. As an element ignites, it gives off a distinct lightwave frequency. Positioned around the chamber are 21 sensors, each calibrated to a specific element's wavelength. The intensity of the lightwave indicates the concentration of the element and a computer converts this data into parts per million. Accuracy is within 1/2 PPM and results below 2 parts per million (PPM) are considered insignificant.
Oil viscosity is also reported to show different ratios of solvents, neutral stocks, and the highly-refined bright stocks of the various brands. Viscosity is the "thickness" of a liquid; honey has a high viscosity while automatic transmission fluid has a low viscosity. The TC-W3 lubricants have to be "thin" enough to flow through snowmobile oil injectors at -40 degrees centigrade and mix easily with fuel. At high internal temperatures, the oil has to be "heavy" enough to provide lubrication and to contain the additives. Too much solvent dilutes the lubrication properties and not enough makes the "thick" oil resistant to passing through filter screens.
The analysis chart shows differences in ALL the oils except for Walmart's and Exxon's, whose certification numbers are not alike, but the viscosity, elements, and concentrations are. This project is not about proving whose oil is best, but showing there are different chemistries among popular brands, contrary to some opinions.
We also performed our own tests. Equal amounts of the oils were mixed together and observed over several weeks for "gelling'. TC-W3 procedures only mix one sample with a reference oil. No incompatibilities resulted. No gel formed, either, after introducing a small amount of water to simulate condensation buildup. A larger quantity of water quickly settled to the bottom of the jar, displaying a distinct emulsion layer.
Manufacturer's Recommendations
Citing the highly competitive marketplace, most of the companies were reluctant to talk about their ingredients or substantiate claims for their products. They mentioned proprietary formulas and trade secrets as the reasons and stated their oils exceeded TC-W3 specifications. The motor factories were very supportive and generous with information in response to our inquiries.
Pennzoil has since introduced Premium Plus Oil, a partial synthetic blend. They would not give out any data on it but said that is better than their lower priced Premium brand and an advertising campaign is forthcoming.
Several years ago, Yamaha changed its Yamalube 2 oil formula to an improved outboard lubricant called Yamalube 2M and came out with Yamalube 2W, formulated for high- revving PWCs. Only the 2M is TC-W3 approved and 2W should never be used in an outboard or mixed with outboard oil. It is ironic Yamaha warns in its owner's manuals not to use any silicon, phosphorous or lead in motors with Oxygen sensors, yet its oil is the only one containing phosphorous. "It is only part of an anti-wear compound," says Claude vonPlato, manager of Yamaha Parts & Accessories, "and the very small amount of phosphate doesn't affect the sensor... Yamaha is in the business of selling engines. Therefore the performance of the oil formula is the primary concern, not the cost. I recommend that people stick with one of the motor manufacturer's top- of-the-line oils, no matter what motor they are running. All the motor manufacturers have the same agenda when it comes to oil development."
Don Schultz, a Mercury lubrication engineer, echoes Von Plato's comments about OEM oils and adds, "The Mercury Premium Plus formulation has been proven to be a superior product when used in high output engines in severe conditions and this unique superior performance formulation costs more to produce." Mercury has two grades of oils and a racing oil. Premium Oil is the lower-cost brand and the label states that this oil is a value-priced product that "meets the needs of low- to mid-horsepower outboard engines". Premium Plus is Mercury's top-of-the-line oil and is recommended for high-horsepower and Optimax motors. In a November 1998 service bulletin, Premium Plus is recommended over Mercury's expensive Performance Blend racing oil for Pro Max and Super Magnum outboards.
Both motor representatives state that the molybdenum in their products is not the same "moly" particles in "miracle" car oils. This molybdenum is part of an antioxidant and antirust compound, spelled with 26 letters. As a comparison, an analysis of ordinary table salt would show a poisonous gas (chlorine) and an explosive element (sodium) combined and named sodium chloride.
OMC's Director of Product Management, Dean Devore, says each of OMC's oils has a place in the market. Nauticpro is manufactured for mass merchandisers to sell as a value- priced, approved lubricant for the cost-conscious consumer. Johnson/Evinrude oil is a better oil for all-around use, corrosion protection, and engine longevity. FICHT Ram oil is a semi-synthetic, which was developed for the high temperature DFI motors and contains a proprietary compound to remove carbon particles from engine parts in new and used outboards. Asked why OMC oil is recommended for Johnsons and Evinrudes, Dean answered, " Each year we spend over 200,000 hours testing our oil formulations in the most severe conditions. Our formulas exceed the TCW-3 requirements by as much as 35%. Just as our propellers are designed to match the power curve of our outboard, the oil we sell was engineered by OMC and it matches the needs of the engine. As we have made advancements in chemical technology, we have increased the detergency of the oil. Carbon deposits are the worst enemy of any two-stroke engine. Our oil formulas are engineered to attract carbon and remove it from the combustion chamber."
Observations
In conclusion, any approved TC-W3 oil will lubricate your outboard; however, there are chemical and performance differences between them. Each oil marketer states theirs exceeds the specifications and will not void your outboard manufacturer's warranty; yet no aftermarket mineral oil advertises they are better than an OEM. The factories would like you to use their lubricants and do have the expertise and testing facilities at their disposal. Each motor manufacturer says they work in conjunction with the additive suppliers and the oil companies to improve their lubricants and to develop new products, while no one else can use the same additive package and formulas as theirs.
To save customers money, many places sell bulk oil if you bring your own container. Sometimes you can save over 40% this way instead of purchasing individual one gallon jugs. Talk to other boaters or call dealers and marinas to find these savings. If you are a large quantity user, consider buying a drum of oil for yourself or to split with several friends.
Although OEM oils have good deposit cleansers, the manufacturers still want you to clean out carbon with one of their products. Read your owner's manual, use a high quality oil, service your motor according to the manufacturer, and utilize a carbon cleaner (spray or additive) regularly to keep your outboard in peak operating condition with a long, trouble-free life
Acknowledgements
Many people contributed to this article and without thanking them for their time and trouble, this story would not be complete. Ted Bernhard ,CTC Analytical, went over and above the call of duty in helping with this endeavor. Dean Devore, OMC; Don Schultz, Mercury; and Claude vonPlato, Yamaha, spent valuable time explaining their respective company's lubricants and answering our many questions. From NMMA, Tom Marhevco furnished testing procedures and TC-W3 guidelines as well as an education in "oilology". Pennzoil's Darci Sinclair and Infineum's Martin Meyers donated videos about TC-W3 outboard oils and their testing. The owners and employees of Bluewater Boats, Chip's Marine Service, Lucenti-Bonds Marine, and K-D Marine, from the Daytona Beach and surrounding areas, donated their time, facilities, and supplies.
Spectrometer Analysis of TC-W3 Oils
(Results in Parts per Million)
Aluminum
Silicon
Boron
Calcium
Iron
Zinc
Tin
Phosphorous
Molybdenum
Viscosity
@ 40° C cSt
Texaco
Havoline
Wal Mart
Tech 2000
Exxon
SuperFlo
Pennzoil
Premium
59.6
Lubrimatic
Ultra Premium
Valvoline
Outboard Oil
jwall116
Thanks for the repost of data.
This isn't a brand war. Any TC-W3 is suitable if thats what the manufacture calls for.
Once again, this was to show to lubrication differences between two pennzoil products. I feel 100% confident running any TC-W3 product in my engine.
bassman284
I would guess that Mercury and Yamaha have a reason for that although I have no idea what it is. I assume it is something in the engineering or construction of their motors that makes it advisable.
As an example I would point to ATF+4 automatic transmission fluid that Chrysler specifies for their automatics. In the past I've read some of the specifics of this particular transmission fluid and really can't remember any of them off the top of my head. Short answer, if you use anything other than ATF+4 in your Chrysler transmission, you will be very, very unhappy.
