Penta 290 DPC - SP 1.78
mrd4739
Do any of you guys have a link where I can get the details on my outdrive?
I do have all the info off of the ID plate.
290 DPC - SP 1.78
Prod. # 872204
SN# 3102127641
Some details of the boat. 1977 Wellcraft 26' sun hatch cuddy. 454 W/ the outdrive described above.
Looking to R&R the out drive.
Thanks
the 1.78 ratio is only for big blocks
do you have a DP or an SP. DPC is a Duo-Prop
the DPC came out about 92 so your boat has been repowered
use your serial number and get info at volvopentastore.com (or follow the links on the iboats forum page to get there)
if you want to remove the drive, just follow the info in the stickies...its a 20 minute job (less if you have done it every year like you are supposed to - more if you havent done it in years)
if you just want to look at the manual http://boatinfo.no/
