Penta 3.0 ('97 Four Winns) air/fuel adjustment -- where is the vacuum port?
soundquest
I am attempting to adjust the air/fuel mixture (2bbl Holley Carb on a Volvo 3.0 -- 1997 Four Winns Horizon) and need to know where the vacuum port is on the intake manifold. Thank you.
Ayuh,..... Welcome Aboard,..... Boat motors rarely have a vacuum port,.....
jerryjerry05
Your best bet, get a FACTORY service manual.
The Clymer and Seloc are ok but nothing like the factory book.
kenny nunez
If the engine does not stabilize with the metering screws 1.5 give or take 1/4 either way either the carburetor needs rebuilding or something else is wrong with the engine. There should be a pipe thread plug on the top of the manifold that can be removed and replaced with a hose barb fitting.
use an un-lit propane torch and your tach when adjusting AFR
