Penta gimbal bearing removal help!
hawkboat
I have a a Volvo Penta sx-m model 3868893. I had a bellows failure which ruined my gimbal bearing. It is a ball bearing type bearing and the bearing was hives out...balls from the bearing were in the bellows.
We have had a heck of a time pulling the rest of the bearing pieces out. We made a slide hammer, about 5 lbs, and it won't budge it. There appears to possibly be some sort of bearing retainer but I don't find any evidence of any retainers in my research. Before we make a 10 lb hammer I wanted to verify that this bearing should pull out and no removal of a retainer is necessary.
no retainer. to aid in getting the bearing out, take a can of keyboard spray, turn it upside down and spray the bearing. this is pure freon and it will spray out the nozzle as a liquid and freeze the bearing. take care not to spray it on your skin. this will shrink the bearing a bit to help
hawkboat
Thanks guys. As a guy I used to work with frequently said "if all else fails use a bigger hammer." Guess that plus keyboard cleaner is what I will be doing.
The puller wont work with the inner race and bearing balls on the ground like the OP has
hawkboat
Finally got it out! Major pain. Now awaiting delivery of new parts and get this thing back together.
once together, inspect annually and follow the other recommended maintenance intervals
