5.7 L Alpha One Gen 2 (GM small block). Replacing T-stat and want to use Perfect Seal on upper (cover) and lower (at intake manifold) T-stat housing gaskets. Temp sensor and overheat alarm sensor thread into housing. Lower gasket has the four rivets to maintain grounding of the housing. Is use of Perfect Seal routine here? Does it cause any problems with maintaining the grounding of the T-stat housing? Additionally does anyone use Perfect Seal to light coat the O-ring between the T-stat and the housing?
Thank you, JEC
Thank you, JEC
