pigeon laker
- Joined
- Jun 19, 2008
- 47
I've been reading through this forum for awhile and learned alot about outboards,but really no solution to my problem.Motor is a 99 Merc 115,used to run great,would rip the rope from a skiers hands if i gave full throttle and was almost scary when at top speed.After the winter(was winterized at dealer)it has lost some power.Seems sluggish out of the hole and top end not near what it was.I have lost about 300-400 rpm's.Brought it into the shop and everything seems OK.compression is good,lots of spark and fuel to all cylinders.Mechanic says try a smaller prop,but that will not solve anything.I rebuilt the fuel pump,removed and cleaned the carbs,lync and sync,new fuel filter,still no help.As well,the bottom plug is alot cleaner than the rest.Almost like new,while the top 3 are quite black.Iswitched the plugs around and the dirty plug came clean in the bottom cylinder.I can't think of anything else but the bleed system.How do you check it?By the way,I was getting about 5000 rpms before and now down to 4600.I know this is a really long post but I might as well ask all my questions at once.I also ran a can of seafoam mixed with 3/4 gals of gas through it,no difference,but I did notice the rpms jumped quite a bit as the small gas can was running out.That is why I am suspicious of the bleed system and thinking the bottom cylinder is flooding.Thanks in advance.
