JSMoore
- Joined
- Sep 5, 2010
- 110
I run a 1997 Evinrude 90 SPL, (E90TSLEUA), on a 19ft center console boat. The motor runs absolutely flawless at all speeds. Compression is 120, + or - a pound or two in all four cylinders. It's propped for 5200 RPM at WOT and typical loads. And, I get about 30 knots on the GPS.
Sounds OK. But, this rig has always seemed just a little "sluggish", some how. The boat is rated for a 115. And, I'm sure a re-power to a 115 would light the fires a little brighter. But, that ain't an option.
However, a buddy offered me a set of carbs off his locked-up 115. The carbs are exactly the same as mine except for the bore. Now.... I know changing the carbs ain't going to turn my motor into a 115 because of the differences in the exhaust side of the thing. But, I would think it might open it up & give it just a little bit more "umpfh". So, my questions are: Do y'all think a set of 115 carbs on this 90 would make any NOTICEABLE difference in power? If there would be some difference, would it be enough to justify the expense of cleaning & kitting the 115 carbs and installing them on my motor? Would it be likely that I would have to re-jet the 115 carbs? Or..... perhaps it would be best to just let well enough alone?
I appreciate any educated opinions y'all might have.
Thanks!
JSMoore
Thanks!
JSMoore
