Performance Tips
andrew j cox
Hi Guys, I have a 77 V4 85HP on my boat, are there any performance tips for these old V4s to ring a bit more power from them, simple bolt on stuff etc
Faztbullet
That's a small bore (3.375) motor and not much you can do to "hop" it up other than get boat/motor set up best as possible. Remember that a powerhead rated motor and is only about 80hp at prop
emdsapmgr
Since it's a small bore block, you won't be able to find any higher compression heads. The stock ones should yield about 125 lbs-still decent compression when compared to the last crossflows made- which were in the 90's. They will be ok. With your engine, you should be able to install a set of 1 5/16" carbs, perhaps from an older 135 crossflow. They'll bolt right on. Also, add the 4 rubber intake filler blocks from a 79 140 hp engine. They'll add 3-5 hp. Are NLA, but you can still find them. If you want to pull the powerhead apart, you can square off the intake and exhaust ports-improving the breathing capability quite a bit. You should expect you'll have to lean the carbs out somewhat, as they will overfuel your block-depending on what you do to it. A set of composite reeds will improve the idling and midrange, maybe 100-200 rpm's on top.
dropbear68
Thanks guys some good food for thought there, sounds like I need to find some outboard wreckers and round up some bits, my eventual plan is to find an old 135 and rebuild it, I had one of these old 85s but a much older version late 60s johnson version with the same hydro elec box I had it screwed onto a little 15 footer and it was a freak geez it went quick, I like the reliability of the old V4s and there still plenty earning there keep, there are several 115s locally that are very cheap but there just power heads and I never trust anyone who says yep shes a good motor mate and they only want 100 bux for it, I smell rats from a long way off lol
dropbear68
In regards to higher compression heads the stock items cant be shaved to boost comp?
emdsapmgr
These crossflows use domed pistons. I'd be careful when considering shaving these heads. If shaved too much, the pistons (domes) could hit the heads when re-installed. It won't take much shaving to wind up with a set of junk heads. Your heads will make plenty of hp the way they are.
