I just purchased a used pontoon boat, and i plan to fish at night for several hours. I'll only have a few accessories that i'll be powering at night (anchor light, radio, maybe a few small LED interior lights, and probably a cell phone on a charger), but i don't want to be stranded in case i stay out for 10hrs with accessories powered on. I've read about the Perko battery switches and will be ordering one this week. Is the install very easy??
I have the standard cranking battery already that came with the boat. I'll be purchasing a deep cycle for running my accessories at night. I'd like to place the deep cycle in a battery box and store it under the rear seat for easy access, along with the battery switch (pro's or cons on this location?)
Am i correct in thinking that all i need to do is -
1) take the cables that are currently on the positive terminal of the battery and connect them to the COM terminal of the switch
2) run some 8GA wire from the positive terminal on battery 1 to #1 on the switch (same for batt #2 and position #2 on switch)
3) run some 8GA ground wire to same grounding point as current battery
I'm hoping to test out the panel switches soon (boat's still at the boat dealer) and make sure everything's wired correctly, and i'll need to install a 12v cig lighter port to the dash as well (which i'm thinking is just going to pos and neg terminals behind the switch panel).
Is any of this correct? I'd like to save myself some money as the dealer charges $85/hr for labor
