Pertronix coil question
sockpatty
My question is on the voltage going into the coil and whether or not I'm too run another wire. The coil is the flame thrower2 0.6 ohm part#45011.
with ignition on I have 12volts on the wires that go to the positive terminal. From what I read,that is good. But since the the internet has either not enough info or too much info,its got me double thinking this.
I'm running the igniter2 part#91146a.
so basically I'm just looking for a confirmation that I'm good to go.
so, what engine and ignition system are you working on?
sockpatty
The engine is a mcm 3.0 liter 181. No serial number.
it's a points ignition being converted.
achris
More fish than mountain goat
You do need to run a new 12v wire. That wire that you are measuring 12v on it a resistance wire. With nothing on the end, yes, you'll see 12v, but as soon as a load is on it, that voltage will drop, and the system may stop working.
Chris......
