Re: Pertronix Ignitor II installation-OMC sterndrive
Hey Guys, thanks for the posts I'm just getting the chance to read. Computer is going back in the shop as it still isn't quite right.<br /><br />I installed the Pertronix II Ignitor, Coil II, new cap & rotor, wires, and plugs. KaGee's wire color hint put me onto a wiring diagram in Sealoc which solved the resistor problem. The ignition system now spits little lightening bolts. <br /><br />I can't wait to get in the water, but my Rochester 2BBl is off to Flying Fish for a rebuild. This will give me time to finish the "OMC shift interrupter fix".<br /><br />I stand corrected on the shift issue. A reread of Sealoc showed me where I was confused.<br /><br />Since I need to do the "shift interrupter fix" I have more questions. Where is the E.S.A. module physically located in the 4.3L ignition system? (The diagram that came with my Pertronix Ignitor II shows "To E.S.A. module" where its shows "To shift box" on KaGee's, all else is the same.) The wiring diagram I have in Sealoc shows one gray wire attached from the negative side of the coil to the module. The gray wire is where the "fix" in inserted. However, my boat has two gray wires on the negative terminal of the coil and I'm not recognizing this anywhere in Sealoc. Just want to hook up in the right place. Any ideas?
