PIC of Oil Water or Oil
dsinger
I dont know if this photo is good enough but I wanting some opions on if this gear lub is watery or just aireated.. I only ran the motor on the ears in the main reason I am asking and have never seen the oil wi this low of hours.
tashasdaddy
Re: Water in Gear Oil or Normal
what picture?
dsinger
ONe more try
Bob_VT
Still no photo's but, water should not be in the gear oil. You have a seal failing somewhere. If in doubt drain it into a glass container or a clean 2 liter soda bottle, let it sit overnight and by morning you will know for sure.
dsinger
I dont know how to make this work
rickdb1boat
You have to have them hosted at someplace like photobucket.com...It's free....
DHPMARINE
someday I too will master posting pics,but until then ......
change the oil and use the boat.After awhile,drain it,look at it.
Advice above is great,but basically look at it.
You'll know if water is there.It won't look like what you put in,but it should.
DHP
tashasdaddy
hope your not in saltwater.
KYHunter2
Postthatpic.com, is very easy to use and free also.
Just download to their site, and then you can get the link to post here.
If its at all milky looking ,you have water intrusion.
Check the little plastic washers/ seals , on fill /drain screws . They are often the culprit .
Happy 4th,
KYHunter
dsinger
dsinger
Thank You at least I learned something but the photo suxs.
dsinger
I put it in a plastic jug like you said so here is the jug photo
