Pick up for towing 12m
Status
Not open for further replies.
briangcc
Are you sure on the length? 3.3ft (roughly) per meter puts you around 39ft long. If that's correct you're well out of the territory of a 1500 series pickup truck. Time to upsize, dramatically. Probably 3500 series with dualies provided you're not oversize on the beam at which point you may just want to look at a slip or commercial hauler.
Good luck with the search!
what does the boat on the trailer with all the gear and stuff weigh?
then compare towing ratings.
a 12 meter boat could be an inflatable, or it could be a sail boat or an express cruiser
a typical 12 meter boat cruiser style boat will weigh in about 32000# dry (14515kg), add to that the 8000# (2720kg) of trailer plus gear, fuel, etc and your total weight of well over 40000# is well over the towing rating of even a 1 ton diesel pickup which runs out at about 31000# (14000kg) Max. PERIOD.
your looking at a specialized tow vehicle. maybe a F550 or F650 with a goose neck 5th wheel.
Status
