matthew1981
- Joined
- Sep 6, 2011
- 6
Hiya everybody
I have been having a few probs with a boat i bought from ebay (i know... bad idea,lol). So the engine starts ok. Sometimes have to turn key 3/4 times to get it started. It idles and revs perfect... for about 20/30 seconds. Then it seems to loose it's revs. No matter how hard i push the accelerate stick down it dosnet make any difference. It just idles slow then it cuts off. Bit hard to start back up. Although it does... For a very short time then stalls. So far i have changed the cooling propeller, got rid of all old petrol. Put in new petrol and oil. Mixed spot on 50/1. Checked all fuel lines. Checked the fuel filter.(Line must be ok between here and petrol tank as the filter was full of fuel. No debris in fuel filter. I have noticed that once engine has started and run for a while the prime bulb goes down a little. Not like a vacuum though that many others report. Just maybe 3/4 full (like before you prime it). i Checked over all electrical wiring and all looks good. Today i took out all 3 carbs and have cleaned them. Going to put them back in tomoz. I have also checked compression. Its all fine. One thing i have noticed, I have read up that it could be the coil. I am going to get a multi meter to test the coil on monday. So what do you guys advise after i put the carbs back in. The spark plus have also all been changed. Another thing, 2 spark plugs always have dark fuel on them and the other spark plug has more clear looking fuel on it. Any advice would be a great help. Im totally stuck and dont wnat to pay a mechanic a fortune to have a look when i feel i can do it myself. Thanks everybody.
Matty
Also one more thing.
The boat has a rev counter and heat dial. Neither are working. I have gone through wiring and from what i can see they are both wired correctly. Any idea's ??
Matty
