picked up 76 70hp johnson what prop is correct for this motor
shawpdx1
the prop on it is watsted not sure of stock prop it came with also no spark on her its a dark green motor with white cowling says 70hp seahorse good motor? comp was 138 in all 3 cylinders.
Boss Hawg
Re: picked up 76 70hp johnson what prop is correct for this motor
Boat size, type, what you use it for, ect is needed :confused:
I have a '87 70hp Johnson & it's great :D
FWIW i run a 13X19 on it pushing a 16' fiber bass boat ;)
mobiletec
mine came with a13 1/4x 17 on a 16 foot fiberglass
kenmyfam
You need a prop to suit your load, hull and type of use. There is a "standard" prop that your motor originally came with but that does not mean that it would be suited to your needs.
shawpdx1
I have a 16' seaswirl open bow IM on the fence to either go with my 85 85hp force or this johnson for some reason im leaning towards the johnson the name says it all really all 3 cylinders are at 135psi
Bill3434
I have a 1977, 70hp. can't tell you what size since my marina guy has it whyl I restore my boat. But like others have said it depends on the boat. Needs to go WOT about 5500rpms with the boat you have. You don't want to over rev. I tested mine with just me in it and 12 gals of fuel. Ended up with what I started out with. That is likely to change since I'm restoring my boat, you wouldn't believe all the wet wood that was taken out.
steelespike
This is a 3 year old thread.Your not likely to get a response.Oh wait a minute you just did.
You should start your own thread about your project.
Be sure your boat holds it shape as you gut it.you don't want to end up with a hook or too much rocker.
Bill3434
Thanks, didn't notice it was a three year old thead. Yes I started my own thread on my project.
