Re: Picking/Installing a on-board battery charger
Jay, any battery charger that I am familiar with is powered by 110V AC. These units are used to charge the boat batteries while at dock, or while the boat is on the trailer in your driveway. If you are wanting to charge your second battery via the engine while the boat is running, that is something else.....not a battery charger.<br />It would help if you posted what year, make and size engine you have.<br />If you spend most of your time running the outboard and very little time trolling, you could use a battery switch or battery combiner to charge both batteries from the engine. If, however, you do considerable trolling, your outboard's alternator will take forever to recharge a drained deep cycle battery.<br /> Post some more info on your boat and how you use it and what you want to do.
