Pickup Coil
Tim Bell
1991 MerCruiser 5.0 Engine died. Thunderbolt trouble shoot guide said how to test and it was the pickup coil in the dist. Changed and started right up. After about 5 to 10 min. it died again. What could be the cause?
Tim Bell
theblob
Banned
Re: Pickup Coil
Pick up coils are funny.they have to practicly be touching.the closer the gap the better.something may have slack in it changing the gap.
bonzoscott
Re: Pickup Coil
Tim Bell
Did you try that again? Add - clean with steel wool any and all connections.
hivoltg
Re: Pickup Coil
You need to verify voltage to the coil.
Either that coil needs a voltage ballast or you have a alternator voltage regulator issue *if you are burning up coils that quick*. What was you volt meter reading when it was running?
Fun Times
Re: Pickup Coil
Tim Bell
For carbureted engine models, The proper name for the sensor mounted under a Mercruiser stock OEM distributor cap is "ignition sensor". A "pickup coil" is used on older EFI engine models. Older EFI's also use a "ignition model" mounted under a OEM distributor cap where your ignition sensor is located.
The most common things that could keep damaging the ignition sensor are, voltage spike within the ignition system, bent/loose rotor hitting the ignition sensor, or wobble on the distributor shaft allowing the rotor to hit the sensor, Bad ground.
Make sure you battery cables are clean and tight at both ends to avoid voltage spike. Also check your alternator voltage with a multimeter.
Good luck.:)
