Wishiniwuzfishin
- Joined
- Jan 17, 2010
- 415
I have several factory O/E OMC 6 gallon tanks, some with the obvious vent in the cap and one that appears to have no vent. I have read before that even this tank should have a vent somewhere even if it is not obvious. But if the tank sits in the sun with the cap on tight, it builds up pressure inside because it "hisses" as the cap is opened. So if it does have a "hidden" vent it must be clogged.
But I believe I have also read that there are actually vent-less tanks and they are vented thru the fittings on the fuel hose. If this is true, IS THERE A DIFFERENCE in the fittings designed to be used on the normal vented tanks with the vent built in the cap and a non-vented tank?
Thanks in advance for any information.
