rothfm
Ensign
- Joined
- Sep 26, 2006
- 915
Maybe this will help others...
I had my Johnson 115 powerhead on the workbench (with flywheel), and needed a cheap way to hold things still to remove the nut and while using a puller. Made a simple wooden holder-See pics
The "arm" portion is long enough to rest solidly on the bench. The Circle has a large hole to accomodate my 1 5/16" Socket, and it has the 3 holes for the Flywheel threaded bolt holes. I used two identical pieces of 3/8's (I belive) screwed together to make it rigid.
Worked great taking the nut off. Now its on flush up against the flywheel with the Harmonic puller over it, with 3 bolts threaded thru and into the flywheel while I'm tightening daily to get it to pop off. No Pop yet, but should one of these days.
If anyone knows how much I should actually crank on the puller bolt?? I'm using a 1/2" drive Ratchet that is about 8" long, its pretty tight. Havent used a breaker bar on it. Its been on 2 days, and I am lightly tapping it with a brass hammer occasionally then tightening a bit more.
Oh, I used those very long heavy cable ties to tie it thru the bench to hold it down while cranking.
