Pilot Screw Plug Removal
Recently bought a 2004 50HP 2 stroke (Model # 50TLRC) on eBay. Motor has obviously been sitting for a long time. It runs fine at WOT, but is hard to start and idles poorly.
I have changed the plugs which helped a little, but not much. I am assuming that the carbs are gummed up and I have a carb rebuild kit and diaphragms for the fuel pump ordered.
The carb kits contain replacement pilot screws. The carbs on this motor also have brass plugs preventing access to the pilot screws. Anyone know an easy way to get these plugs out? The only way I can see to do it is to drill them out, which I would prefer not to do if it's not absolutely necessary.
Alternatively, once the carbs are disassembled, can the pilot screws and seats be cleaned by spraying carb cleaner into the passages from inside the carbs without removing the pilot screws?
