Got a radio with a power plug I'm going to have to make up a power cable<br />for.<br /><br />The chassis receptacle is a 4 pin microphone female fitting. It's one of<br />the common mike connectors with a threaded ring.<br /><br />I need to connect +12vdc to pin 1, and pin 4 is ground.<br /><br />My problem is that I'm not sure how the pins are numbered.<br /><br />When I'm looking at the chassis/socket, there's a keyway. The count could<br />be either clockwise or counterclockwise. Which is it? In other words, is<br />pin #1 to the right or left of the keyway?
