Pin Spanner Wrench
larryo
Can I get a tip on where to pick up a reasonably priced pin spanner wrench for my 2007 F150's trim and tilt motor? Thanks
You could make one real cheap out of some flat stock, a drill and couple of dowel or roll pins.
Capt Ken
If it's been in saltwater, don't try to save the caps. I order new caps and seals, then use an air impact to break the caps loose. That usually ruins the cap from being used again. But it's either that or spend all day getting them loose.
larryo
Thanks. Answers from opposite ends of the poles, both great.
