Pinion gear 1996 9.9
josh01
I have a 96 Gamefisher that I just purchased it looks great and runs perfect but I just took it out and if I go over 1/3 throttle it grinds and shakes. I came home and pulled the lower apart and found the pinion gear is chipped up. Everything else is ok (I think) I looked up the pinion gear on-line and it says no longer available. The part # is 43-819251a1 is this an old part # or would another one fit? Could I find a Mercury lower and just replace it? Thank You
corm
Re: Pinion gear 1996 9.9
Hi,
You will need a Force lower unit for it.
A Merc one will not fit.
