Pinion Gear preload
johnbhite
Ok, after reading manual #11 for setting the preload on the double bearing pack on the drive shaft, I tightened the nut down to where the washer barely touches the pinion gear, but my problem is that the rubber O ring wont allow the assembly to slide into the houseing so I can set the rolling torque... am I doing something wrong?? This is on a Bravo 2 by the way.
Pete104
Re: Pinion Gear preload
You set the rolling torque prior to installing driveshaft assembly.
What are you doing? Or trying to do?
#11 tells no lies!
johnbhite
#11 tells no lies!
I am setting the preload out of the drive housing on the bench, and then installing it in the housing to set the rolling torque. I thought that is what the book is stating. But after I get the preload set the O ring prevents the assembly from sliding in the housing.
Don S
Did you put any lube (Oil not grease) on the oring?
johnbhite
Would it be a bad idea to tighten the retaining ring all the way and then proceed with my rolling torque setting
Pete104
Whatever your doing, you need to seperate the bearing pack. They need to be free & slightly loose. Seperate in a press, like book shows. Then tighten nut until you get the pre-load spec. A little at a time.
If you have done this before, say on an older Alpha!? IT IS Not the same procedure!
johnbhite
Ok, what I had here was a drive shaft change, I took the gear and bearing assembly of the old drive shaft and put it on the new drive shaft. I have followed the book as far as setting the preload and then installing the drive shaft in the upper housing to set the rolling torque spec. But what happens when I get the rolling torque spec right, the shaft will not come out of the drive housing, wont budge. This is my procedure so far,
1- On the bench, I tighten the nut and washer down just until the nut touches the washer
2- Place drive shaft assembly into drive housing, tighten spanner nut hand tight
3- Start to tighten the pinion gear nut in small increments until a rolling torque of 6 to 9 inch pounds is achieved
Is this correct, or am I completely off base here?
Pete104
How do you know you have preload set properly? It has to be relaxed for reassembly! You can't just take the bearing & gear assembly and put it on the new driveshaft.
Setting the preload is done with the bearings seperated & pulled into position with the pinion nut. The o-ring is in place & will set in position while achieving the rolling torque.
I accidentally hit post before I should, sorry!
Pete104
Page 3A-37 shows disassembly of the bearings. Just move it slightly. Then put the o-ring in place & then set preload. If you get it too tight, you MUST go thru this again!
johnbhite
Alright, I think I may have found my problem. The drive shaft that was in the outdrive was the newer style meaning it has the different style U-joints. I had a different drive shaft out of an older drive that has the older style U-joints (the servicable ones). I think the problem is that I simply swapped the pinion gear and bearing assembly from the newer style drive shaft to the olderstyle drive shaft. The bearing assemblies have different part numbers between the two, So I am assumming that the physical characteristics are different. Does it sound like I am on the right track, and do any of you know what the differences are between the two bearing assemblies. Thanks a bunch
Pete104
Definitly on the right track. There are a few different combinations of yokes & bearings.
IS why serial numbers are so important!!!!
