Piston fit
Hdhammy
What is the piston fit spec. For a xr6 150 with 3.50 bore?looks like I to much on all cylinders
So what do your pistons measure 1/2" from bottom of skirt?-----And what do your bores measure just above the ports ?----Post some accurate measurements.
Faztbullet
Bore size is 3.501 and piston 1/2" on skirt is 3.494 +/-.001. If bore measures 3.504 or larger it needs rebuilt
