Piston number
Award
number under piston is 745 4973 is there a cross reference number to use I have been searching on internet to find rebuild kit for 78 merc 80 hp
the casting numbers that you find wont have any correlation to the part number you buy.
Chris1956
Those pistons should be very available, as they were used on vast numbers of motors over the years. Sierra and others should have them.
The replacement is likely a 2 ring piston with keystone rings.
merc850
Checking my parts list for my '75 850 the Nrs. are close but you have to use the serial Nr. which could be on a plate between clamp bolts for searching.
Click image for larger version  Name:	Serial-Nr-location.jpg Views:	2 Size:	178.9 KB ID:	10690707
Faztbullet
Is it a high dome or low dome??? Does it have a power port??? Nobody offers a "piston kit" per say as you will need to purchase all parts separately. You can get a gasket kit....
Post a picture...
harringtondav
I made a quick check on my favorite parts look-up site, but more info is needed. Like model no. and number of cylinders.
Award
Harringtondav
78 merc 800 thunderbolt 4 cylinder
Award
Fatz
it wont let me upload a pic file size or something not sure
flyingscott
What is the serial # of the motor? You will need that to get the correct parts.
harringtondav
Yes, a motor s/n will verify this info. Don't purchase anything until you do. There appears to be only one Merc 800, 4 cyl. with nine s/n breaks. I checked and the pistons are common. 774-9137Axx. xx 12 is std., xx 13 is .015" OS, xx 14 is .030" OS.
The OEM pistons are NLA, but new old stock is available on eBay, etc. Sierra 18-4535 is the .030" OS version, and is available here at iBoats.
https://www.mercurymarine.com/en/us/parts-and-accessories/parts-catalog Hit "Launch Catalogue"
Faztbullet
You can get them from WSM also in .010, .020, .030 and .040. Make sure you mikr the cylinders as these engines wear a taper around the ports and this causes idle and die in gear issues.
Award
Fatz
i did have it mikd and he said it was tapered towards the top of cylinder ( by spark plug) is this not good should I have it bored ?
Restrictor mod I use is.------I install 8-32 stainless setscrew with 0.040" diameter hole.-----Never to fall out like the nylon factory ones.
harringtondav
I couldn't find your engine manual on Boatinfo, but several manuals for similar motors state a .003" limit for taper, out of round, size. If you are over this, you need to bore & hone enough to straighten this up. .010" increments.
Your pistons are 2.875" Std. I don't know the hone finish size clearance spec. The small end of your tapered bore will be close to factory. Per Faztbullet the WSM link is below. $720. If you need to go .030" over, the iBoats Sierra part is also below. $472.
https://www.wsmparts.com/Search/Par...6fe-86ef852ff5e1&AcctCnbr=&AcctAPKey=0#search
https://www.iboats.com/shop/catalogsearch/result/?q=18-4535
NO----The bore is 2.875" --------The piston is smaller to fit that bore with proper clearance.
harringtondav
...my bad. Dyslexia. So he should buy OS pistons to match a 2.885", 2.895" or 2.905" bore clean up size and the pistons will be sized for correct clearance? I rebuilt my KAW 500 Triple 33 yrs ago, but I've forgotten the process.
Faztbullet
Before you sink a lot of $$$ in this motor, if it sentimental or a full restore for a project...go for it. If it just a running motor to use for the weekend you can add a few hundred to repair/parts price and get a later model 3 or 4 cylinder looper...
