Piston problems
Jay Martin
My HydroTec built motor that only has 155 hours on it blew another piston this morning ,this time it was #6, first time this happened the motor only had 99 hours on it and it was #2.
The problem is the top ring, the pin that holds the ring in place is moving and allowing the ring to rotate untill it gets in the exhaust port then it's all over.
Does anyone have a clue why this is happening?
The two times this has hapened is when I'm getting up on pad, I hear a ticking sound and shut it down, the rest is history. motor is turnning no more than 3800 rpm's when it go's.
This is a 2.6 liter Phase III.
99yam40
Re: Piston problems
Is a HydroTec built motor even a Yamaha?
If not why post in this forum?
mommicked
Re: Piston problems
Friend just had the same ring pin problem w a big Mercury engine. but he had alot of hours on it.
