roastinears
- Joined
- Aug 26, 2004
- 36
Bought this motor off ebay for $400. Traveled less than 190 miles round trip to pick up. Two problems though. Rectifier is literally blown and need to replace one piston. I borrowed motor lift to get the motor out of the bed of my truck and mounted on my boat (replaced a Chrysler 75hp). Started checking out the motor and found 20psi on top starboard piston. Pulled exhaust cover and both rings gone. Cylinder wall has two small scrapes in direction of piston travel, but no other visible scars. The scratches are just detectable with a fingernail. I just got my piston set (piston, wrist pin, rings, etc) and the OMC service manual (part # 393765) for this motor. My question is this: will I have to re-borrow the motor lift? Looks like just removing the intake manifold will not be enough to get to the connecting rod cap. OR will I be able to replace that piston w/o having to pull the powerhead just the intake? I will lightly hone out cylinder once I pull the old piston out. Thanks for the replies in advance!
