piston ring question
i have a 50 hp mercury early to mid 80's...it is a 2 stroke...is it ok to use automotive piston rings in an outboard?
thanks
bryan
Chris1956
Re: piston ring question
Bryan, Piston rings are custom designed for the piston. I doubt you will find automotive piston rings to fit your outboard pistons. Your dealer or aftermarket sources will have rings for your pistons. If you look around the web, you should find a reasonable price ($2-3 ea).
CharlieB
NO
You might get lucky and find rings that look like they might fit the bore and the thickness BUT.....
the rings ENDS are machined to fit the ring locating pin pressed into the piston
2 stroke rings are located, not free to rotate around the piston as the ends could snag a cyl port and self-distruct.
thanks guys for the info.
does anyone know a place online that sells them cheap?
thanks again
bryan
