Re: piston swap
Question.. why just two pistons?..
..a motor that old is probably ready for 4 new .020" over pistons/rings and a fresh bore, new main bearings and a COMPLETE gasket set..-replacing ALL gaskets...
with a cold motor.. shut off! - grab the flywheel and see if you can move it side to side...either direction... there should be no movement! If there is movement..you need to replace the end bearings too!
If your motor uses "cracked" rods (big end).. be very careful to get them realigned PERFECTLY! OMC makes a tool to do this with.. I have better luck with my hands..but I've been building two cycle race engines for 30+ years!
This is not a hard job. Pretty simple really.
take pictures of the wiring and anything you are NOT INTIMATELY familiar with! Use plenty of assembly lube!
