pistons/bearings/crank?
spamreef
I am going to overhaul my 1980s 80hp merc over the winter.I was just wondering if it would be a good idea to replace ALL of the pistons,rings,and bearings,while I have the motor all apart. I know that sometimes this can be bad because the motor has broken-in a certin way. should I just replace the bad parts or all parts? The reason i ask is because i once rebuilt a 1970s chrysler with the exception of the bearings and after the first season the lower cranck bearing let go and sent #2 piston through the head(ouch) but I also have replaced bearings on a few jetskis and had motor noise afterwards...........
Texasmark
Re: pistons/bearings/crank?
Well dude, your Merc tain't a Chrysler.<br /><br />Why you overhauling it in the first place?<br /><br />Mark
Laddies
Banned
Yes, to the bearings and rings, if the bores and pistions are within specs. don't worry about them
spamreef
it has slight motor noise and evidence of water in #4 cyl.
