Looks like I need a rebore and new pistons for my 1998 75 hp Force. The bore was quite worn although not damaged or grooved. It had a substantial lip at the top which is too large to remove with a hone.
I’ve looked around and have found a couple of places selling Wiseco pistons. One listed the kit as containing “Rings, wrist pins, wrist pin bearings and retainers” and the other didn’t mention the wrist pin bearings. I'd like to order the correct parts first time.
A couple of questions.
1 Are the wrist pin bearings needed or usually part of the kit?
2 When fitting new pistons what happens to the needle bearings at the wrist pin end of the con rod? Are they reused or is there a different type of bearing used with the Wiseco pistons? I'd like to know how to fit the new piston to the old rod.
I hope this is the last surprise the motor has for me.
Thanks again for the help.
TwoFish
TwoFish
