Re: pistons for a 350 4bbl mercruiser engine
by new engine, what do you refer to? Was it a reman form somewhere? or a buddy or you build it, etc... so many things can be a factor... combusion chamber volume, was the cam degreed off a bit (have seen that done before... can result in much lower static compression and a dog of an engine even though it runs), etc, etc, etc...
what kind of pistons do you have in it? 9as in dished, domed, flat, flat with valve reliefs. etc...
Oh, what are the casting numbers off the heads.
a factory long block has a lot of potential advantages as well...
