pitch question about gears from v8 put in v6 outdrive
renken86
i was wondering if someone might know what would be the best pitch to get for this. the gears in the upper housing came out of a thomas with a ford v8 in it and i put it in the upper housing for a 4.3 v6 in a renker. the porp now is stamped 15 x 17 but seems like it takes a while to plane out. any help please. i think the rpms are running aroune 3000 or 3500. sorry dont exactly remember.
thank you
run2car
Re: pitch question about gears from v8 put in v6 outdrive
What outdrive is on the boat?
renken86
sorry its a stringer outdrive 800 i believe. i just had the gears that was in another boat with the ford 302 so i just used them in the housing for the 4.3 v6. im trying to figure out what is going to give me the best thrust for the engine.
thank you
Ayuh,... Sounds like ya need a 15x 11"....
renken86
Thank you. I will look around to see if I can find one. I just had the gears so I figures why spend the hundreds of dollars. Maybe I should have.
Howard Sterndrive
13p pretty common- in stock here at iboats.
11 was made but will be a trick to find.
you could try a 13 and see where you end up
