pitch question
i was loking at 4 blade propellers and was told that in order to use one and inch reduction in pitch is recommended but i cant seem to find a 4 blade prop with a 12 inch pitch can i still use a 4 blade prop with a 13 inch pitch or will that cause problems:confused:
SparkieBoat
Re: pitch question
you should repost this in the prop section..you would need to post your RPMs at WOT and top speed with your current prop, also include boat and motor info.
