Rebuilding a 65ESL73R because of water getting into the bottom cylinder. Pulled the crank and discovered the bottom rod journal has moderate pitting. I've tried to clean it up using 120 emery but some of the pits are quite deep. They also run across the bearing surface. I've read that JB weld can be used to fill in pits and then be sanded down. Opinions?
