pitting in the head
cadilacboat
I have a 67 evinrude 40 hp. I blue out the head gaskit. i took it apart and found pittining in the head its not shinny its all cabind up. I was wondering what is it caused for? I was told it was a ring but im not sure if it all ready been replaced. is there any way i can tell if it just happend or if its been replaced. Is it somthing i sould worry about if its not a ring? thanks
F_R
Re: pitting in the head
How about the piston top? Is it beat up also? If not, then the damage, whatever it was, has been repaired. That pock-marking conditon happens when something breaks and pieces get into the cylinder and the piston pounds it to bits. The pocks won't hurt the head, but a beat-up piston is cause for concern.
cadilacboat
the pistion looks fine. so just put the headgaskit on and it will be fine hopfully.. do you know what tha torqe is for those bolt?????????
