Pitting Question
BigBobsBigBobbingBogBoat
Guys,
Still working on the old Volvo Penta Aluminum Outdrives. Many thanks for all the help so far.
I've read a few posts on repair but I've got one big question. The outdrive's I'm refurbing have been stripped down to bare aluminum, but they have significant pitting which I intended to fill in with JB Weld Marine.
The sticky posts suggest using Alodine to etch for painting. I'm assuming I should put this on AFTER I've filled the pits with JB Weld. Is that correct?
Thanks!
Bob
v8mgbal
Re: Pitting Question
Hey B, if you are going to paint it you do not need alodine as it only protects bare aluminum. if it is bare AL then I would alodine first then fill the pits.
steve riddell
If Your using Rattle cans, I would use a GOOD Quality Zinc Chromate 1st, then topcoat with a good engine enamal!!:D
Yacht Dr.
Hello BigBob..
Well at first I woulda said Alumiprep, Alodine..then fill..
But your probably going to be sanding your JB smooth which will break the surface back down to alum...
So at this point I would say AS long as its clean.. do your JB..sand and fair.. then apply your Alumiprep then Alodine..then your Primer and paint coatings.
YD.
