Seems after I put a new impeller in it, affixed the lower end, when I put the pivot pin back. It wouldn’t shiftCan you just put it back??
Thanks, What do you mean by cap? I Take lower end off and bottom part of propeller case? Sorry I just don’t get it.Take lower unit off.----- Take the cap off.-----Assemble with clutch dog in forward and shift rod in forward ( up into the unit ) and install cap.----Install pin.
Thank you for your advice. You see, I have the motor on the back of the boat. With its weight, I am unable to manage the weight to put it on its side. I'm working with it in the "full up"position. That being said is it possible to remove the skeg like that without having all the gears fall out? I truly appreciate your help.Bottom half of the gearcase.----Also called the skeg.-----Or lay motor on it's side and see if you can position shifter so you can see the hole.------Did this job many times 50 years ago when I worked at a Johnson dealer !!
Thank you sir, I'll give it a try once it stops rainingPut the motor in the tilt position. Lay it on its side, pivot pin hole up as best as you can. Stick pin in hole. Now, move shift lever (cable disconnected), and work pin CW and CCW until it goes into hole. They usually have a shape on the end of the pin that will help.
