Fcdave
- Joined
- Jun 10, 2011
- 180
Questions regarding PL vs PB for bedding my floor....... Will PL stick to the cured epoxy on the stringers and underside of deck with just a sanding to ruff it up???
I'm considering using the PL Premium instead of thickened epoxy.....can I walk on the deck in 12-24 hrs later or do I need to stay off it for 72 hrs ???
I'm thinking of going the PL route to save some mixing thickened epoxy and to control the bead of adhesive on the stringer tops ( I'll have plenty of that in tabbing deck in ) ....I would later remove screws used to clamp floor down....then drill out holes and inject with epoxy resin.
Any comments appreciated!
