Re: PLACE WHER I BOUGHT MY BOAT TOLD ME I COULD NOTCH MY TRANSOM WHAT DO YOU GUY
Hi J.B. Cornwell,<br />It will probably took me at least 5-6 years before I need to repower the Selva 40hp 15" shaft kicker motor. I will stick to 15" shaft because of the slight weight saving but if I can afford to change boat, I'll get a 20" shaft kicker motor and keep the transom intact. My 40 hp Selva is only 54 kg [118lb]. My next kicker motor will be any brand around that horsepower range and weight. I am really looking at the best power to weight ratio. At the moment, Selva 40 hp cross flow is the best in class. The next best is Johnson 30 hp cross flow. Maybe by that time some manufacturer will compete in power to weight ratio for 2-stroke outboard around 30-50 hp range. I hv to keep the kicker motor as light as possible to maintain balancing on a long but narrow beam boat.
