Planer Boards... Mast or "mini's"?
mars bar
Hi fellow members, I'm refitting the boat for Walleyes on Erie. I used to have a mast and used the big board on the old boat, but I see people using those small plastic boards like "Off Shore" and "Yellow Bird. I tried one up north last summer and wasn't to bad, caught fish, But what happens when the water starts to chop? Any advice would be appreciated.
Mark_VTfisherman
Re: Planer Boards... Mast or "mini's"?
I like the OffShore in-line boards- easy transport, and when on a boat without a mast as a guest, you can still use them.
Do I use them? I prefer to have multiple Offshore "shower curtain hook" releases and the bigger boards on a mast (or even tied to my bowcleat without a mast!)- I can stagger out several lines with one setup, and most often you can land fish without having to clear other lines.
However, I will say that I have used borrowed inlines a lot more often since I dislike the space that the big boards take up on my small-ish boat. This year might be a transition year to running the big boards a lot more often, though, as I have a second boat - a 19' Starcraft. That has a LOT more room.
With that said, I will comment that I am not a very dedicated board user. I run plugs, cranks, leadcore, diver disks and dipsies off to the side, and bouncers off the bottom for walleye, and have caught enough fish that developing my board use hasn't been that big of a deal.
Of course Erie is a whole different game than here in the northeast with our smaller lakes, but I plan on trolling South Bay on Champlain after the Walleye opener- the shallow water might dictate running boards as there may not be enough depth to keep my dipsey divers from hanging up during maneuvers.
Those are my thoughts- mileage may vary but it has worked for me.
Ayuh,... I've got a set of Super-Skis,+ a big ole Cannon double-reel mast,...
I used to use it all the time,...
Til 5 or 6 years ago, I tried a set of Church Tackle's "Mr. Walleye" mini boards...
Since then, I haven't used the Big skis,... Matter of fact, I pulled the big mast off last year...
These mini-boards take the chop as good, or better than the big skis,... The big boards would dive in the worst of the chop...
The minis just bounce over the chop...
If it gets Real Bad Rough, it's time to try a different tactic anyways...
Btw,... I can stack as many minis on each side, as I could with the big boards...
I usually run 1 or 2 to each side, but have managed 4 on a side...
mars bar
Ok, Thanks. I do have two of the mini's so I'll try them first before I mess up my bow. I was concerned about waves, as Erie can go from 1 meter to several in a short time. Good advice, thanks guys. I wish we could all sit down and have a beer and a few laughs together someday. Mars
Mark_VTfisherman
Re: There are a wide variety of classes and races available
Dear Mr and Ms Moderators. We all would appreciate your censoring the previous spam poster.
