djarrett
- Joined
- Jul 9, 2007
- 20
I recently got a new boat and i have a few questions.
This is my second one but my first is only a 14' aluminum with a 7.5 merc. The boat i just got is a 1984 procraft 1650v bass boat with a 1984 yamaha 150 ETLN. This boat has power trim and a jack plate. When i take off i trim my motor all the way down and go. The boat comes up on plane real quick and seems to level off fine but my tach is showing 4200 rpm's. The owners manual says to run it at 4500-5500 rpm's. Now when the tach is showing 4200 my speedo is showing around 50 mph. As i start to trim the motor up the engine increases in rpm's and i'm showing 4400 on the tach and about 55 mph. Am i supposed to keep trimming it up until i reach the correct rpm's or should they already be in the correct range after i been going wot for a little bit before i start trimming? I am kinda nervous about going any faster because this a new territory for me, i got the boat to fish out of. I'm really a newbie at this and have read all these post about how bad it is for the motor to run out of its range, this boat will have to last me for at least a couple of years. It also has a hydro foil on it and i am thinking of taking it off and trying it without it, would that help bring the rpm's up also? Also did a compression check and had 105-110 on all the cylinders with a cold motor because i thought maybe the engine was a little weak because of the low rpm's.
Anyway sorry for this being so long but i tried to put all the info i have on here.
