Plastic Cam puley remove in Tohatsu 8, 9.8 15 20 hp
raczekp1
Hi.
is there any tool to remove cam puley from valve shaft. This cam puley is made in black plastic.
i dont want to brake it or brak cast iron valve shaft.
any tips?
pvanv
I have never needed one; it's not a press fit. I suppose you could use a 3-arm puller if needed.
raczekp1
well,it stack very hard. i put under the puley 2 flat screv drier and tap into shaft. the end of story was broken top of cam shaft
on top of the puley are 2 holes. i think its for puler.
the right puler is 3AC-99736-0 +3AC-99737-0
pvanv
On an MFS8/9.8?
If there are 2 threaded holes, yes, you can use a harmonic balancer puller.
So now you need a new cam as well. Ugh.
No mention of a puller in the Factory service manual for the MFS9.8A3...
