This boat had been in storage for 10yrs. One of you guys told me the plastic gear could go out since it had set up so long. I did see the option for the electric oil pump system. I may go that way. But, Can I just pre mix? At least temporarily? Will the motor run at WOT if the oil sensor unit doesnt know what to do? What about the beeper. Can I disconnect it from the oil system only and still keep it hooked up for the overheat?
I going back out there now to run a compression check.
Thanks for any help.
