The grab handles on my 2017 Stingray 198ls pulled loose. I have shimmed the holes with zip-ties and tightened them up, but it's a poor long-term solution. The issue is that they used stainless wood screws from the factory. I'd like to through bolt them with a nut and a washer. Access from behind is a PITA. I thought I would remove the sidewall cupholders to try to get a wrench behind the handles. Access in the bow is even worse as I will need to go through the speaker holes with monkey arms. Is there a recommended procedure for removing the clear/white fasteners that are holding in the cup holder? I tried prying on them with a panel clip removal tool and they aren't coming up like an ordinary car clip. Is it best to just drill these out? Are replacements available or do I go with white automotive tree style clips? Hopefully they didn't also glue this in with 5200.
