Gods Favor VIP 1800
- Joined
- Sep 3, 2007
- 56
I just recently did some remodeling on my VIP interior. I found that a bunch of the lower sections of wooden seat supports were completely rotten about 3 to
4 inches up from the carpet. Same with the engine cover. I figured it was due to the boat being kept uncovered and when it rained it would soak the carpet and all the wood parts were setting right on the "wet rug" until it would dry itself out again. The wood acts like a straw. It soaks up the water over and over again until it become rotten. Well I found a solution. I got some scrap pieces
of 1/2" thick white plastic panels Lexan type material. I used it to replace many
of the areas where the rotten wood was. It was cheap it will never rot! You can cut it like wood with a band saw. And many shapes and contours as well.
I had to use 1/8" thick aluminum to brace my engine cover at the bottom edge.
But you cannot tell it was added. I know now why more and more manufacturers are using less wood and more fiberglass and plastic in their boats.
It last longer and won't crumble like wood does.
Gods Favor VIP 1800
Gods Favor VIP 1800
